Under dark sky conditions as well as in suburban light pollution, broadband filters cam improve the quality of the view in the eyepiece. Astrotech sells a 1.25" broadband filter for around $50, currently on sale for a bit less, while the Orion 1.25 filter goes for around $75.00.
Under dark sky conditions as well as under suburban light pollution, I came to four conclusions while viewing various objects in my 16" f4.5 dob with a 10mm ethos and a paracorr in place together with a freshly coated(enhanced)primary:
1. The AT filter generally provides a view producing more nebulosity than does the Orion filter. This was most noticeable on M27 under dark sky conditions and less so under moderate light pollution on the little dumbbell.
2. The Orion filter generally provides a sharper image, producing a clearer star dot and a sharper core on most objects.
3. The AT filter may have a bit of an edge in viewing brighter galaxies as this appeared to be the case in viewing a few of the brighter members of Pegasus and Perseus under moderate light pollution.
4. The AT filter produces a slightly brighter view under conditions of moderate light pollution but not necessarily a sharper one than the Orion model.
I like using either filter and I don't have a favorite between the two models. I'll continue to use both filters, switching between one and the other, as I view various objects. I find it interesting to view the subtle differences between the two filters.
I also had intended to report on the Orion O111 2" filter but sadly the filter threads were not compatible with my filter slide, meade and explore scientific eyepieces. I have an Orion 2" ultrablock that threads without difficulty but the 0111 is a no-go. Other amateurs have reportedly noticed the same thing. It's too bad since the Orion 0111 had an individual transmission report with high values. Darn filter threads!
