Baader Hyperion 8mm
Started by gtober, 01/07/2007 01:18AM
Posted 01/07/2007 01:18AM Opening Post
Just tried my new Badder Hyperion 8mm on Saturn, Luna, and Trapezium the other night in my f8.1 FS128 apo. Not the best viewing conditions with the full moon, but seeing was very good for a change here in Montana. Excellent EP in my novice opinion. Sharp across the entire field, no light scatter, very comfortable viewing. Able to reach focus in my 2" star diagonal using a 1.25/2" adapter, or directly with the 2" barrel option.
I'm so impressed that I'm considering the 5mm and 13mm Hyperions as possible replacements to my more expensive Nagler Zoom 3-6mm and Meade 4K UWA 14mm respectively. I'm continually having to reballance my scope on my UA alt/az mount when changing EPs with varying weights, and this might be a good option to avoid such hassle. Although I doubt I'll ever part with my massive 2.3lb Nagler T2 20mm.
Has anyone tried Hyperions with the finetuning rings? These can vary the focal length of an individual EP. The 8mm EP with the 14mm finetuning ring effectively becomes 6mm; 8mm EP with the 28mm ring becomes 5mm. I'm wondering how/if these rings affect performance: ie. how the 8/28=5 combo would compare with the regular 5mm Hyperion without any rings.
Thanks as always to all for the great advice!
Greg T
Molt, MT
