RICHARD COFER
"Bivalent" Eyepieces
Started by Herbert Kraus, 07/20/2005 04:38AM
Posted 07/20/2005 04:38AM Opening Post
This question has surely been asked and answered before, but I'm too lazy to do the research: When an eyepiece is configured to be used in either 1¼-inch or 2-inch diagonals or focusers, does it give a wider true field of view in its 2-inch than in its 1¼-inch configuration? Specifically, I note that Orion's new Stratus wide-field eyepieces, which some reviewers have indicated may be of pretty good quality at a reasonable price, can be fitted in both 1¼-inch and 2-inch focusers. Suppose I obtain a 17 mm Stratus e.p. and use it in an 80 mm refractor, would it make any difference if it rides in the diagonal's 2-inch barrel or in the diagonal's adaptor for 1¼-inch eyepieces?
Posted 07/20/2005 05:24AM #1
Hybrid eyepieces have a 2" skirt for reasons of safety and convenience. The clear aperture is limited to that of the 1.25" barrel and the field stop of the ocular so the answer to your first question is no.
Dave Mitsky
Posted 07/20/2005 05:53AM #2
The FOV does not change nor does any other aspect of the perfomance. It just allows you to use the EP with or without a 1.25" adapter.
