Jay Messeroff
Lunar & Solar Transits
B&L ASP 18mm mystery
Started by mirfak, 02/22/2009 08:21PM
Posted 02/22/2009 08:21PM Opening Post
I have two of them. The second bought sight unseen, thinking to make a binoviewing pair.
One is 1-3/8" tall, the other 1-13/16". The field stop is the same in both. The shorter has bluish reflections, taller had light violet.
Of all the folks that own one, which came first?
Which is more common?
Any other info?
Dont know much about them, thanks.
John
mirfak's attachment for post 45747
Posted 02/23/2009 03:22PM #1
I'll have to check and see what length my 18mm ASP is, it was original equipment with a circa 1981 Criterion RV-6. The design is a symmetrical plossl (2 doublet lenses). and it always worked well for me at slower f ratios (the RV-6 is F8). I think mine is the longer version but I'll have to check for sure.
Joplin
Posted 02/23/2009 11:32PM #2
Just to follow up, my circa 1981 example is the same as the taller one you have except that the top is engraved " B&L CRITERION A.S.P." and has a circle Y logo I don't see on yours. It also has light violet colored reflections from the eyelens. I'm pretty sure that the taller version is the later of the two since I've seen a few newer old stock 18mm ASP's that also had the longer barrel.
Joplin
