Capillary action from cleaning
Started by mtsabalan, 11/20/2010 03:57AM
Posted 11/20/2010 03:57AM Opening Post
I have an eyepiece that appears to have spots between the glass layers. I assume it was improperly cleaned and the liquid solution made its way inside the eyepiece via capillary action. Any ideas on how to correct this?
Thanks
Posted 11/21/2010 11:33PM | Edited 11/21/2010 11:35PM #1
Michael,
If it is an expensive eyepiece I'd consider sending in for cleaning before doing this myself. Eyepieces can be complicated to disassemble and reassemble correctly, especially for the inexperienced. This is what is going to be required to address the issue you describe.
If it isn't an expensive item, however, it could be a great learning experience for you. There is quite a bit of good information available here on AM and on the web. Some of the key things you'll have to consider include:
1) Get familiar with the construction of different eyepiece designs you will be cleaning (lens elements, groups, and the mechanical housings).
2) Determine what tools you'll need to take the eyepiece apart and put it back together without damaging it.
3) Setup a very clean, dust-free environment to perform the cleaning process.
4) Learn what cleaning agents to use (and which ones NOT to use), and other expendable items to use to clean the surfaces of the lens elements.
5) A strategy for keeping the lenses clean while handling them during the reassembly steps. (i.e. lint-free gloves used in clean-room environments work well)
Note: The biggest challenge is noting the arrangement of the lens elements in the various groups during dis-assembly...
You will need to be certain you are able to mate the exact lens surfaces together in the exact same order.
It can be tricky to take the lens apart and preserve this condition throughout the cleaning process.
You will need to be methodical in your approach.
-Gary
