In choosing to replace a broken 2" Celestron 0111 filter purchased years ago, I decided to get another from Adorama for around $77.00 while its Baader sirname sells for about $100.00 more from the same vendor. As many amateurs have commented that the Celestron 0111 is a rebadged Baader 0111 model, lest there be no mistake that it is as my Celestron delivered from Adorama has the Celestron name on a paper glued on its plastic case while the Baader name and logo are etched on the back of the same case!
At any rate, I decided to put the newer Celestron Baader filter up against my Lumicon 0111 at the LAAS site in Lockwood Valley on April 18, 2015. After an hour or so past sunset the seeing settled down and the transparency was excellent so I pitted the two 0111 filters up against one another on Thor's Helmut. Suffice it to say that the Lumicon does what it does best and it was obviously better at bringing the image NGC 2359 to life. The image appeared brighter than the Celestron/Baader model in my 16" F4.5 dob and more intricate details could be discerned. While the latter filter does improve the view, it's decidedly much less effective than the Lumicon filter. My past impressions of the Celestron/Baader model is that its sharp cut-off spectral lines darken the view a bit more so it may be somewhat more optimized in an application in a light polluted environment. The Lumicon is still better either way but I believe the Celestron/Baader model performs as best it can in a more light polluted situation where its effectiveness seems more evident at the eyepiece.
I have to say observing last night during new moon at the LAAS site was a real treat. Springtime truly marks the season for the realm of the galaxies. My sky quality meter varied from its best reading at the zenith from 21.63 to several at 21.50 and 21.53 with the lowest read at 21.46. All readings are quite respectable for this dark sky site and better than what I usually see during the summer months. I attribute good readings to the seeing/transparency at the time. Visual detail in the ringtail galaxy in Corvus was excellent considering its relatively low position in the horizon. All I can say is I had some of the best views of the usual suspects in Leo, CV, CB, ursa major and, of course, in virgo that I have ever had in the past. It got cold at 2:00am and early in the morning but the views were definitely worth it...
