I finally had the opportunity to test the ES14mm 100 AFOV versus the meade 14mm UWA 80 AFOV under dark sky condition at Mt Pinos on Tuesday evening, June 21.
First, a word about seeing conditions at Pinos. They were excellent last night, among the best I've seen up there. It was a pity the moon rose above the tree line at about 12:30 but up until then, I enjoyed dark skies without the usual presence of the light domes from Los Angeles to the south and Bakersfield to the north. Prior to night fall, there were clouds above the mountain, and these were not forecast by various weather sites I consult; nor were these present on the clear sky clock. I think this was a case of the mountain generating its own weather.(Maybe Floyd can comment on the latter phenomenon.) I noticed a heavy inversion layer over Santa Clarita on my way home in the morning and I suspect a cloud bank settled in under the Pinos area that helped keep it dark. I had 21.55 on the sky quality meter at 11:15pm. M81 looked like a somewhat smaller version of m31 in the eyepiece and m82 seemed to explode in the eyepiece. Up until moonrise, it was a great night.
It was also colder than I expected for this time of year, especially when we've warmed recently in the past few days. I always come prepared for Pinos and I found myself gearing up early last night as if I were observing in colder months. Finally, the outhouses have been removed so bring your own portapotty or use a tree.
Now down to cases, most observers use wide angle eyepieces to observe DSOs and the like. I put the ES 14 up against a Japanese-made version of the meade 14mm uwa. First target: the Sombrero galaxy in Virgo. I like to see a sharply defined dark lane that helps define this galaxy. I felt the meade eyepiece bested the ES on this particular challenge. Score one for the meade. Next, the ringtail galaxy in Corvus. Corvus doesn't ride high in our skies so observing DSOs in this constellation can be challenging. I felt both eyepieces put up similar views. Rate this one as a tie. Next, onto the Siamese twins. I felt the ES 100 did a better job in defining and displaying the twins, with the meade close behind it. Score this one for the ES14. M51 needs no introduction and it looked great last night. Definitely better, hands down, in the ES. It really light it up and defined it much better than the meade. I did prefer the view through my 10mm ethos but then you need to factor in the additional magnification. In either eyepiece, however, the views were splendid. Next, onto the whale and the hockey stick. While both eyepieces performed well, I'd give the edge to the ES.
So, the meade scored an initial victory on m104 but fell behind on other objects. I liked the immersive view of the ES100 as compared to the meade which felt "downsized" in comparison. They're both good eyepieces but I'd give the edge to the ES14mm 100...
