I was at Mt Pinos on Wed evening (8-3-11) in order to see first light through my new ES 30mm ocular.
Before I begin the review, a couple of mundane issues need to be discussed. First, I had already advised you that the outhouses had been removed from the parking lot pf Mt Pinos. I further advised you to bring your own portapotty or find a suitable tree with your name on it. Did you listen to me? Well, judging by what I saw and smelled, you(and you know who you are)decided to use, in mass, the rear end of the Nordic base ranger building at the end of the parking lot. Do you think the rangers are going to appreciate seeing and smelling the essence of your presence?
Remember, only you can prevent human forest fire poopy...
Now, for the observing conditions: Excellent transparency and good seeing throughout the evening. The 20% crescent moon set at about 10:15pm and, as such, did not pose much of a hindrance to deep sky observing. One other individual who was present at the weekend observing event came over and described the zoo-like setting on last Saturday evening. He wasn't an amateur but he is a low-light level nature photographer and he seemed quite adept at lens capabilities in dark conditions. At any rate, I showed him the summer DSOs in my 16" f4.5 dob.
His first comment on observing the veil in my ES 30mm was how remarkably sharp the image was to the edge of the field. And that was without the paracorr in place. Yes there is a little bit of coma around the edges but virtually all major eyepiece aberrations are very well controlled on this eyepiece. I was primarily concerned about astigmatism with a 30mm eyepiece and a large exit pupil which brings into play astigmatism from an observer's own eyeball but I didn't detect any. A paracorr sharpened the edges a bit more and tightened the star images as well but the eyepiece holds its own quite well. If the maker was shooting for nagler-like performance with this eyepiece, its pretty much there.
I actually preferred the image of the veil thorough my meade 28mm swa 2" eyepiece in combination with a paracorr. I felt it was more defined and brighter than the image in the ES30mm, probably because of the increased magnification and reduced exit pupil. Remember that a large exit pupil from a 30mm or larger ocular in a fast scope can actually decrease the effective aperture of your scope because your eye can't dilate enough to accommodate it.
I observed the crescent nebula through the ES30mm and it gave me one of the best views I have ever seen of this object. It was truly outstanding and much better than the comparable view through an 30mm BW Optic 80 degree 2" ocular.
While the eyecup is comfortable and effective, it also limits the AFOV so you'll want to drop it down when observing from a dark sky location. Eye relief is good with minimal blackout. The eyepiece is a bit heavy, weighing in at around two pounds but I had no problems with balance issues with it and a pracorr combo in my astrosystems dob.
So, to sum up, I didn't detect any significant distortion, contrast or color issues with this eyepiece. I do like it but I think it probably cuts down the effective aperture of my scope, as my eye apparently can't quite dilate enough to accommodate its large 6.7mm exit pupil and I believe this may have accounted for the veil appearing brighter in my meade 28mm eyepiece/paracorr combination.
Bottom line, it's a keeper...
