Experience with Orion Epic ED-2?
Started by davidcolton, 08/01/2003 01:03AM
Posted 08/01/2003 01:03AM Opening Post
I'm thinking about getting an eyepiece with a short focal length for my refractor later this year. It would have to be economical (under $75) and I noticed that Orion offers their Epic ED-2 eyepiece in a 5.1mm and 3.7mm. It also appears that they have a fairly wide lens. Does anyone have experience with this series of eyepieces, particularly the ones with a shorter focal length?
Posted 08/02/2003 09:08PM #1
The reviews on the Excelsis site mention that when you hold you eye up close to the Orion Epic ED-2 eyepiece (which appears to be the same eyepiece as Celestron's X-Cel series) it will "blacken out". What does this mean?
Would it be better to get a long focal length eyepiece (in the 5mm to 2.5mm range) that has a small lens? I wear glasses but take them off when I view, so an eyepiece with long eye relief is not that critical.
Posted 08/05/2003 09:07PM #2
Don't know if this will help, but I've been using the Epics and the XCEL's (they do appear to be identical) from 25mm to 5mm for several months on a 8"/f10 SCT. The only trouble I had with blackouts was when I barlowed. Sold the barlow and finished out the set. No ghosting, great contrast, sharp. On really bright planets you will see a reflection of your own eye/pupil due to the size and curvature of the lens ( it's eliminated when I center the object). I tried the Expanse set and returned it due field curvature and radial distortion. I think they may be intended for much faster scopes.
Mark Rice
Keep it dark, or at least keep it quiet. wink
Ultima 2000... and other things
