Iris Nebula
Eyepiece case at night II
Started by jimmoscheck, 03/16/2007 02:24AM
Posted 03/16/2007 02:24AM Opening Post
In a recent thread we were talking about how we store EPs while observing. My friend Doug Scobel made the case that rides on the front of the rocker box.
See post:
http://www.astromart.com/forums/viewpost.asp?forum_post_id=512467&poll_id=&news_id=&page=4
This two part question is for Doug and Floyd or anyone else that might be able to help. I really like the idea of the battery riding on board while in use, but this would add to the weight of the scope on the azimuth bearing. I assume adding this weight would change the size teflon pads needed. Correct?
Also, I have a 17ah battery. I know this is enough to run fans, argo navis, and dew control for a couple of nights. Would this still be enough power if I add a Servo-Cat in the future or will I need more amp hours?
Posted 03/16/2007 03:22AM #1
Hi Jim,
Well, I run my Servocat, Argo Navis and three fans on a 12amp. No dew control though, but I can run it all night on the 12amp and it is still working well. So I would think that 17amp would work for an evening.
The weight could be a problem if the case was not located on the backside. I hang my 12amp on the front lip of the rocker box with no problems.
Keep the weight of the case down by using lighter materials or thinner wood and it should be OK I would think.
Let's see what Doug has to say, he has more experience with the case.
Posted 03/19/2007 07:21PM #2
Hi, Jim, to compensate for the weight of the battery box/battery/eyepieces on the front I offset the center of the altitude cutouts (where the altitude bearings ride) slightly towards the rear of the rocker box. I didn't do anything with the size of the Teflon pads. I'm using a set I got in an Astro-Systems kit years ago. I think the pads are about 1.5" x 2" or so.
I'm only using a 7 amp-hour battery, which doesn't weigh that much compared to the rest of the scope, so what I did may be over-kill.
Doug
