Mark Eby
M33 Triangulum Galaxy
Eyepiece Filter Confusion
Started by eddixon, 04/20/2015 10:35PM
Posted 04/20/2015 10:35PM Opening Post
I am confused about filters because of conflicting information. Take the Lumicon UHC for example. One place says not suitable for scopes under 8". Then another gives it rave reviews on an ETX 105. What is the real truth?? Same deal on the O III filter. Would it be useful on an ETX 125 or not?
Ed
Posted 04/20/2015 11:00PM #1
Ed,
If you are going to trot off into the very dark skies with your ETX-125 for use of brighter planetary viewing, I would say "yes", it is worth it. The filter will remove bright contrast and "make" the nebula appear more up-front.
I know where you're coming from. I too have seen inaccurate ads stating on one page the filters would be "better suited for XX-inch scopes" and then they have someone in there hippity-hopping over how they saw the Horsehead in their 2-inch scope. Okay, not quite like that, but to some similarity.
It is true. To an extent the aperture might be too small to discover the full gains of the filter. I have, for fun, put an OIII on the diagonal of my FS-60c while at M57. It made it contrasty, but SO DARK, it was a ghost. I saw more without the filter.
On the contrary, I put the OIII on M57 with my 18" mirror and M57 began to show very mild knotting.
Why there is no law of when the filter is applied to too small, too large an aperture I'll never know. It would be obvious to me the company that made the statement "Not suitable for scopes under 8." did this because of too many returns or on-the-phone complaints.
Years ago I saw an ad of a solar filter (don't remember if it was Lumicon or Orion) with its box and poised in new condition. Below the filter image were lists of other sizes and prices. Just to the right where it said "SOLAR" it showed an H-alpha photo of the Sun! I wonder how many customers felt "wrongfully dealt" on that one?!!!
Just a few thoughts:
8) FS-152SV sitting in the office
grin Japanes super lucky zen observatory garden
:S Meade ETX-90 finder scope position
shocked Hino Optical Mizar 120SL observatory model
:C SR-4mm eyepiece with a 3x barlow in a 60mm refractor
8O Zeiss Victory 7x42 SFs
wink Having over 135 vintage oculars to play with
smile My life surrounded by wonderful friends and impeccable optics
Posted 04/23/2015 11:53AM #2
The argument for using particular filters with a minimum aperture goes like this: Filters block part of the light spectrum entering your scope. If your scope is small blocking even some of the light entering it may make the resulting image unacceptably dim.
It's confusing because the filters are supposed to block light you don't want to see at that time anyway, so how could the view be less acceptable with the filter than without? My thought is, if you're trying to view an object that might be made more visible with a filter, and it's not, then perhaps you don't have a big enough scope to view that object. Obvious examples are planetary nebulae, many of which respond well to filtered views but are faint, requiring large scopes with or without filters.
