Iris Nebula
Eyepiece starters for a 8" SCT
Started by kbconv, 08/04/2009 05:12AM
Posted 08/04/2009 05:12AM | Edited 08/04/2009 06:10AM Opening Post
I'm looking at getting a 8" CPC or SE Celestron.
Can someone point me towards some affordable eyepieces and sizes. BTW, I'm in my mid forties (ouch), I've read that can affect pupil size.
I'm guessing it would be better to put the money towards a quality barlow and 2 or 3 eyepieces than the Celestron lens and filter kit? I may get a 6.3 focal reducer also.
I was thinking a Orion Shorty Plus Barlow and have heard UO and TMB have some good, affordable products.
Thanks
Orion XT8, color filters and a shorty barlow
Posted 08/04/2009 02:13PM #1
I would consider buying a single "premium" eyepiece like a nagler and then barlowing that with a good 2" barlow. A focal reducer would add a "3rd EP".
A lot depends on what you want to look at. If its "higher power" viewing and you live in an area with good seeing conditions, that the smaller fl eyepieces (like orthos) would be good for the moon and planets. If you want "medium power" viewing that you may want to try wide field eps.
Posted 08/04/2009 05:05PM #2
A widefield, choose one:
Pentax XW40*, Pentax XW30***, Pan Optic 35mm, Pan Optic 41mm**, Nagler T 31mm, TMB Paragon or other inexpensive wide field (visit University Optics).
*=my #1 choice, **=#2 choice, ***=#3 choice
You will need a 2 inch diagonal, if you don't want to get a two inch diagonal delete the above and get a Pan Optic 24mm which offers the most field available in 1.25" format.
For higher magnificiatons: a barlow, I like the Vixen DX, to be used with your 1.25" eyepieces (unless you feel like buying a two inch barlow with an adapter).
Edmund RKE 28mm (delete if you go with two inch wide field options and add 21 mm RKE)
Edmund RKE 12mm
Edmund RKE 8mm
(sold only by Edmund Optical, but available used on the 'mart)
That would be a four eyepieces, and a barlow. Three RKEs will cost $195 new and about $135 used. The wide fields will run $350 to $550 depnding on what you get. Someone will invariably recommend UO orthos, I like them, but I prefer RKEs.
Good luck,
Greg N
Posted 08/04/2009 05:16PM #3
In slower scopes like SCTs, I still like the Antares 32mm wide field Erfle. It is affordable, useable and offers nice wide field views. It is also fairly light for a 2" eyepiece. The 40mm is no where near as good.
dan
Posted 08/04/2009 06:03PM #4
Thanks for the reply's!
I'm no optical expert at all and hear the SCT is optically a different animal too. Was reading up at http://sctscopes.net/SCT_Tips/Eyepieces/eyepieces.html
Guess it's time to get some club time in also to see for myself. Man, I used to have razor sharp vision and in the past 10 years it's going to crap. 8O Getting older sucks, haha.
Keep 'em comming.
Posted 08/04/2009 07:09PM #5
John Basham said:I'm looking at getting a 8" CPC or SE Celestron. Can someone point me towards some affordable eyepieces and sizes.
One word of caution: Some have advised you to go for 2" eyepieces. Before you do that, make sure the SCT you are getting can handle a 2" diagonal without smashing the eyepiece into the telescope's base every time you try to look at something that is closer to the zenith than about 60ยบ altitude.
Posted 08/06/2009 02:30PM #6
In the 1.25" format the long to medium focal length University Optics Abbe Orthoscopics are pretty good but very affordable eyepieces. Not nearly as wide AFOV as Panoptics, naglers or other premium wide fields, but they are a much simpler design that will work well with a SCT. The short focal length ones though (7mm and less) have very short eye relief - way too short in my opinion.
K. Michael M.
Thanks
