Wizard Nebula
Eyepiece suggestions, please...
Started by go_ahead_ed, 10/03/2005 07:19PM
Posted 10/03/2005 07:19PM Opening Post
I want to get a bit more power out of my 12.5" f/5 dobbie smile
My shortest f/l eyepiece is a 7mm T6 which, when used with my soon-to-be-ordered Paracorr, will deliver about 260x. I'm thinking about a 6mm Radian (about 304x w/Paracorr) and/or a 5mm T6 (365x w/Paracorr). Or maybe a Pentax 5mm XW?
With my hand-driven dobbie I'm partial to wide field ep's so that limits my choices a bit and with the extra glass of the Paracorr I want to avoid barlows...
TIA for your input grin
Ed
Ed Moran
Equipment Forum Moderator - Two of Five
Posted 10/03/2005 08:08PM #1
Do you have a Barlow? If so then the 7mm doubled would give 3.5mm and more than enough power. Otherwise, the 7mm will be a 6mm with the Paracorr so I would say the 5mm would be a better solution and with the Paracorr it will give 4.25mm. The Pentax XW will give plenty of eye relief, but the T-6's will give more FOV. They are all good.
