I want to upgrade the eyepieces for our club's vintage C-14. I recentlly read that the new eyepieces are designed for short focal length telescopes. What is going on, and what modern eyepieces would be optimum for an old f10 scope?
eyepieces for C-14
Started by Mark Wilson, 01/11/2012 07:51AM
Posted 01/11/2012 07:51AM
Opening Post
Posted 01/11/2012 05:18PM
| Edited 01/11/2012 05:18PM
#2
Long focal lengths will work with more EPs, so you can just about get anything and be happy.
With the Ethos line coming on strong, there might be some deals coming on used Naglers.
Get some with wider field of view, it will make everyone appreciate the big aperture and long focal length.
Posted 01/11/2012 06:08PM
#3
For deep sky viewing on my Nexstar 11 GPS, I really like using a Celestron F6.3 reducer/corrector combined with a 20mm Explore Scientific 100 degree EP. Trying to go wider with a 30mm 84 degree EP resulted in severe vignetting so the 20mm ES100 is about the limit. An R/C would reduce a C14's focal length from about 150 to 100 inches and improve its off-axis performance.
Posted 01/11/2012 08:40PM
| Edited 01/11/2012 08:42PM
#4
A few years ago a friend of mine asked for opinions for an eyepieces to use with his new C14. Since he wears eyeglasses I suggested the Tele Vue 26mm T5 Nagler and 17mm Nagler T4 along with a 2x Powermate for when the seeing gets really good. I think he also picked up a 40mm TMB Paragon for a max. FOV eyepiece in 2" format. I've had the opportunity to use the scope with these eyepieces a number of times and they are an excellent complement to the C14. These days the market is a bit different since there are 100 deg. eyepieces available. If I was going to buy just one premium eyepiece for a C14 it would be either the 21mm Ethos or Explore Scientific 20mm 100 deg. Being F10 the C14 will work well with most decent eyepieces of appropriate focal length. The 100 deg. fov eyepieces will give the best wow factor though.
Joplin
Joplin
Posted 01/12/2012 04:13AM
| Edited 01/12/2012 04:13AM
#5
With my C14 I have always preferred:
In mono mode -- Nagler 20mm T2, 22T4, UWAN 28mm, brandon 24mm erfle, 40mm axiom (old style), and 34mm mead SWA (and the 40mm and the 41 pan).
In bino mode -- 24 pans, 16 nags, 23mm axioms (old style)
Peter
Peter
Funding Member
