Flat field and/or Camera Projection eyepieces
Started by mdavister, 08/14/2009 04:18PM
Posted 08/14/2009 04:18PM Opening Post
This might be an odd question, but it does fall into the eyepieces classification. I have a "Starlight" scope that has a focal length of about 150mm to 200mm (haven't exactly measured it yet). But, it has an f-stop of 1.4, so a very quick lens. It was designed to work with a light amplification tube, but I would like to use it with a CCD sensor. The problem is that the focal plane is fixed, and it is fixed about 3mm from the back of the scope. There is just not enough back focal distance to make it work with the majority of cameras out there (or what I even have).
So I've decided on two options:
1) Buy a pair of flat field eyepieces with about a 35 to 45mm focal length (smart astronomy has some nice looking camera projection lenses). Install them such that the 1st eyepiece image plane corresponds to the focal plane of the telescope. Install the 2nd eyepiece such that it's mounted "backwards". The CCD then would sit at the new focal plane. (long ang short, using two eyepieces as a relay lens)
2) Somehow adapt a standard camera/DSLR to just put the sensor at the scopes focal plane. This takes alot more work and machining, but should yield the best results.
I've taken a course on optics way back when, but I was never particularly good at it. Especially some of the matrix operations in dealing with more complex systems.
I'd appreciate any guidance or thoughts that any one has. If anyone has a pair of flat field eyepieces and wants to see how well they make a relay lens, I'd be interested in hearing the results.
Mitch Davister
Posted 08/14/2009 04:33PM #1
I don't see why you would need to use two eyepieces. One should do the trick. Alternatively, get a nice pair of matched achromats and make your own relay lens to fit the distances and aperature you need.
good luck,
dan
