james carter
North American Nebula NGC7000
Good mid-FL eyepiece?
Started by valta, 02/21/2010 05:16PM
Posted 02/21/2010 05:16PM Opening Post
I'd like to add a decent 17-20mm eyepiece to a 40mm WO SWAN for my 8SE scope,
preferably in 2 inch format. The 18mm Explore Scientific and 19mm Axiom have
similar weight and price. I am mostly viewing DSOs, doubles and clusters.
I'd appreciate hearing your thoughts and suggestions. Thanks, Walter
Posted 02/21/2010 07:18PM #1
At F10, either eyepiece would likely do quite well. Given the higher magnification inherent with your longer focal length system, I'd opt for the 19mm eyepiece versus something shorter unless your seeing conditions are particularly good. OTH, if you use a reducer/ corrector, then I'd give some consideration to a shorter focal length eyepiece.
