james carter
North American Nebula NGC7000
Grab and Go EP Case
Started by fblue, 07/04/2007 01:57AM
Posted 07/04/2007 01:57AM | Edited 07/04/2007 02:00AM Opening Post
Well, with the new Grab and Go setup, I needed a Grab and Go EP case that would hold the right EPs for the 80mm APO for an evening of viewing.
I decided to use another of the small Rubbermaid 5 quart cooler that cost $8 at Wal-Mart. These are great for carrying things, well made, double wall and even insulated to keep the EPs from dewing up so quickly.
Thought I would post a picture of a finished one for those who might need something similar.
The plate is made of 3/16 press board and painted to make it look better.
In the case are 22mm & 12mm Naglers, 8mm,5mm,4mm,3.2mm B@/TMB Planetary EPs. This give a good range of power and FOV for the 80mm APO.
fblue's attachment for post 37721
Posted 07/04/2007 04:15PM #1
Another great idea, Floyd! Functional and looks good. If you got a dollar for each of your ideas, I'd probably drive down to Bakersfield from Santa Cruz and help you drink that beer you'd be buying. 8)
