Ghost of Cassiopeia
Keep Nagler 9, and 7 or replace them with Ethos 8
Started by actuary616, 10/01/2009 06:23PM
Posted 10/01/2009 06:23PM Opening Post
Currently, I am using Nagler 31, Ethos 13, Nagler T6 9/7/5 with Paracorr on Sky-Watcher 12" f/4.93 Dob. I found 5 is too agressive under NE seeing condition. I am wondering if I should similify my selecction by replacing Nagler T6 9/7 by Ethos 8, and sell out 5. What's your opinion. Thank you in advance.
Posted 10/01/2009 07:06PM #1
Hi Zhuo,
Well, that is a real good question and no simple answer unfortuanately.
When you consider the difference in magnificaion from 5-9mm with your scope, 300-167x, that is a big jump really with a lot of territory in between. The 8mm will give you 188x somewhere in the middle. But it will not give you the range in magnification that the 3 EPs will give. This means that you are stuck with one magnification, when maybe another would have been better.
So, it could be an OK move, but it has its own limitations too. smile
