I checked the performance of the 16mm SWA eyepiece this evening on my 16" f4.5 scope. Basically, it was a bit of a disappointment. Coma appears much earlier than expected, perhaps about 55% out from on-axis. So it appears the eyepiece can't handle a fast light cone very well. Seeing was initially a poor 2/5, improving at times to a 3/5 and during the latter, Saturn was sharp on axis, with a neutral color, except for the color inherent in the planet itself. A hint of lateral color is seen off-axis but it is quite negligible and I would agree with other reports that it's essentially nil. Although eye relief is said to be around 15mm, I found it to be tighter although not objectionable, unless you happen to wear eyeglasses. If you do, forget it. I did not feel an immersive effect with this eyepiece and the AFOV felt less than 68 degrees.
I was impressed with the view of Saturn on-axis so the eyepiece appears decent enough in this regard.
I could not achieve enough in-focus to use the paracorr with this eyepiece in my scope. If I could, I suspect it would have helped a lot.
In general, I feel it's an inexpensive Chinese eyepiece that works at an acceptable level at its current(reduced)price point and I'll probably keep it but if it was significantly more in price, I would have returned it.
I think I will be able to use the 28mm version with my paracorr since it is a 2" eyepiece and I won't have to use the 1.25" adapter which extends the height of the eyepiece a bit which limits the in-focus that I need with the 16mm 1.25" eyepiece.
I read two reports on the 24mm version that contradicted other reports which reviewed it favorably and I suspect the former two to be correct. One report essentially called it a minor step up from a similar-sourced plossl while the other report simply referred to it as "ok". I doubt it would really be better than other eyepieces costing three times as much, as one user stated in his review.
In general, the main drawback, in my viewpoint, is the apparent inability of the eyepiece to handle a fast light cone. And I didn't get the immersive effect that I would want from a swa eyepiece with a reported AFOV of 68 degrees. I did get a fairly decent view of Saturn but that's about it. I guess for $49.00 bucks it's ok but that's about all. After using higher end eyepieces like a pentax or ethos, you get used to better and the lesser units become more obvious. My report would be more positive with a paracorr in the equation but that's what it would take to clean things up in a fast scope. I didn't really see much in the way of astigmatism so there's hope for this eyepiece with a paracorr or a longer focal length scope...
