Dan Lamoreaux said:
Anyone ever had the chance to compare one of the older Meade 24.5 swa volcano top eyepieces to a Panoptic 24mm or heard of a review between the two? I would like to hear any opinions out there.
Dan Lamoreaux
A few years ago I had a chance to compare the Meade 24.5 SWA to my 24mm TV Widefield. We did this in two different scopes, one was my 12.5 inch F/4.06 Dob + Paracorr and the other was a C-8 (8 inch F/10.)
These are two very similar eyepieces, both in field of view and edge correction but the owner of the Meade and myself both felt that the TV was slightly sharper at the edge. I am not sure if the SWA series was copied from the Widefield series in the same way the UWA's were copied off the early Naglers, it would make sense.
The 24mm TV Widefield is a modified Erfle design, in comparison to Erfle's, it is definitely sharper at the edge in a faster scope, the astigmatism is noticeable but not distracting the way it would be in an Erfle.
So how do these eyepieces compare to the Panoptics?
I still own the 24mm TV Widefield but since have acquired a 22mm Panoptic (as well as a 20 mm Type 2). I have compared the two on several occasions, mostly in fast Newtonians (F/4-F/5 with a Paracorr) as well as a couple of F/7 ED/APO refractors.
The Panoptics are really the step up from the the Widefields (and SWA). The Pans have somewhat widerfields of view, based on field stop, it would be about 65 degrees vs 60degs. The edge correction is noticeably better. Whereas the edge correction of the Widefield/SWA is "not distracting though apparent", the edge correction of the Panoptic would be "Really have to look closely" to see it. In the development of the modern 65 degree eyepiece from the Erfle's and Konigs, my sense is that the Widefield/SWAs are about halfway, the Panoptics are essentially there..
For what it's worth...
