I found that when I started mounting an f/6.5 102mm on my C14, I was "driven" to acquire the full set of XWs. We don't really NEED this stuff, right? But what I mean was that operated a 102mm refractor (and even the FS128, which does not ride the c14) one OFTEN uses eyepieces in the 3.5, 5, and 7mm range, which one NEVER uses in the C14. In fact with the refractor I find I use MOST the very short fls and the very longest fl eyepieces for "wide field goodness" (17x and 25x).
By contrast in the c14 I indulge somewhat in the wide field eyepieces but I don't kid myself: the most I can get is 43 arc minutes and my true wide field views are to be had in the refractor. But I also use the 10, 14, and 20 a lot because they cover the optimal magnifcation range for the instrument and help it do what it does best from 195x to 390x. So when one is operating two such dissimilar instruments it is nice to have a full spectrum set of eyepieces.
I'm wondering how one would handle a similar situation if one were using Naglers, given the different design options.
Thoughts?
regards
Greg N
Thoughts?
regards
Greg N
