Nagler vs explorer scientific
Started by De Lorme, 12/29/2009 06:08PM
Posted 12/29/2009 06:08PM Opening Post
smile Hi I'm De Lorme, Which is the better eyepiece Naglers or explorer scientific ? If you say nagler ,why {being they cost a considerable amount more} ? just don't want to be dissipointed. thanks for any help you can give. De Lorme
Posted 12/29/2009 07:37PM #1
I have not actually tested the Explorer Scientific eyepieces, so I can not give an absolute answer. But, the Nagler has seen no real rivals in performance so far by any 80+° FOV eyepieces. Mostly it is off axis performance, which allows the use of the full FOV without deterioration.
Most all other EPs that I have tested have poorer performance off axis, but good performance on axis. But since you are purchasing a wide field EP for just that, then off axis performance is the real key.
Posted 12/30/2009 12:17AM #2
I've not had the T6s and any Explore 82s at the same time, and I did recently get a 6.7mm Explore 82. This particular FL of the Explore showed as follows:
- softness off-axis around 10% from the field stop due to astigmatism in an f/6 APO. Moving it to a 10" f/4.7 Dob with no Paracorr thing began to get less than optimal at the 50% mark and then rather moderately aberrated at 20% or so from field stop. so not near how a T6 performs. From memory, the T6 had a touch more rectilinear distortion and a touch more lateral color off axis than the Explore, but has no astigmatism from my recollection or notes so overall a substantially sharper off-axis.
- on-axis was quite crisp and really excellent focus snap, better than my T6s used to perform.
- tone was very slightly warm.
- light control/baffling is better in the T6. the bright Moon just outside the field stop showed some reflections in the opposite side of the FOV. These vanished once the Moon was in the FOV.
- contrast and transmission were probably on-par, and judged quite good in the Explore.
Basically, if you have an f/6 or longer focal length refractor it's a very nice eyepiece for the price as the on-axis for planetary is quite nice, better than I recall on the T6 line as their on-axis planetary performance was a nit for me. For faster scopes, especially Dobs would not recommend it.
Whether the other focal lengths perform the same don't know. The 6.7 Meade 5000 UWA performed differently off-axis and was sharp to the edge, overall on-par or a touch better in some respects than I recall my T6 had (RD and lateral color for example). I also noted that the Smyth group in teh barrel was a different arrangement in the MEade 5000 UWA vs the Explore for the 6.7mm units. So their design is slightly different there. Baffling/light control was same in Meade as was in Explore, so not up to the TV standard there.
If you are looking for a less expensive alternative to the T6 line, then would look to the Meade 5000 UWA's over the Explore's based on what I saw in the 6.7mm units of both lines. I actually prefer the overall picture the UWA gives to the T6's and have since acquired the 8.8 and 4.7 as well as a result. Don't know how the units longer that 8.8mm perform though.
Hope this helps.
Posted 12/30/2009 12:29PM #3
Likely the Nagler...but WHICH Explore (I assume that is who you are talking about) Scientific eyepiece are you specifically referring to? Certainly their 100 degree AFOVs are superior to the Naglers in some ways.
Uncle Rod
Time on your hands?
