VDB 142 Elephant Trunk HOO
Need math help with binoviewer plz
Started by [email protected], 09/03/2008 02:46PM
Posted 09/03/2008 02:46PM Opening Post
Okay, my mind is spinning over the math here, and I'm hoping someone can help me out a bit. I have a 16" f/4.52 dob, with a Denk binoviwer. My problem is trying to figure out the magnifications of my eyepieces. I have the 2" OCS with the 1.2 Optical Cell. I have it all the way closed in the lowest position (in other words I did not unthread the OCS at all). I have a dual-arm power switch, yielding 1.2X, 1.8X, and 2.3X magnifications. My problem is that I also have a single-arm stacked in front of the dual, to give me an additional three magnifications per eyepiece. The single arm operates in 1.2X and 2.5X. So.....yeah, this is where I fuzz out. I've got three things going on: the Optical Cell of 1.2X (is this part of the equation anyway?); the dual-arm, and lastly the single arm.
I asked Russ for some help, and he said that the 1.2, 1.8, and 2.3 is what I get with the dual arm switch, but I don't know if he took into account the 1.2X OCS Optical Cell. And that leaves out the single arm in the equation.
I have a 24.5mm Meade SWA set, and if anyone can help me figure this out, I'd be very grateful. Essentially you'll have 6 magnification settings; 3 for the dual, 3 for the dual plus the single.
Thanks in advance,
Guy
Denk II w/nags junkie
Posted 09/03/2008 05:41PM | Edited 09/03/2008 05:43PM #1
Okay, I've been looking at this in my free time today and I've figured this much out (sorry, I purchased some of this three years ago, and I had to put astronomy aside for the past two years, so I forgot some things): I have the 1.2X OCS, which gives my dual-arm 1.2/1.8/2.3X magnifications when the OCS is in the closed configuration, which it is.
I remember Russ saying that when you have to extend the OCS to achieve focus, you are increasing the magnification. With that in mind, does the 1/2" space the single-arm takes up increase magnification?
Now, if that's right, then the single-arm, if I was not using the dual, would yield 1.2X and 2.5X magnification. However, that figure on his website is using the 1.4X OCS optical cell; with the 1.2X cell, I should be getting 1.1X and 2.3X for the single-arm switch.
Here's where I'm still fuzzing: I should be taking the 1.2/1.8/and 2.3X and multiplying by 1.1 and 2.3 to get the two different ratios? That would mean, with the single-arm switch NOT engaged, I would still have 1.3X/2X/2.5X using the dual-arm.
With the single-arm engaged, I would have 3X/4.6X/5.8X magnifications.
To clarify, normally the dual gives 1.2/1.8 and 2.3X With the single arm attachment, those figures jump to 1.3/2/ and 2.5X and when the single arm is used, the second set of magnifications is 3/4.6/and 5.8X If that's so, then my calculations are way off for what I've been using.
Lastly, applying this data to my set of 24.5mm SWA's I get the following (16" f/4.52):
Dual-Arm only: 98X/150X/187X
Single-Arm only: 224X/347X/437X
The numbers seem to look what I'd imagine them to be, especially for the dual numbers. I know that the max setting on the dual is roughly what the lowest is on the combined view, I just didn't think the numbers went that high at 437X. It would explain why I hardly ever view at that setting though....
Please, someone give my numbers a check and see if I've made errors or not. Thanks!
Guy
