Ghost of Cassiopeia
Not your usual XW20 vs 24 Pan Optic Comparison
Started by gnowell, 09/26/2009 07:00PM
Posted 09/26/2009 07:00PM Opening Post
(also posted on CN)
Last night I "won the battle of the dew" but just barely; I'm used to vigorous policing of the C14 corrector.
The XW20 had been my "eyepiece of choice" while cruising for galaxies in Cygnus. So it had been out a long time, with little usage.
I used the Pan 24 for a little bit. But most of the time it was in my eyepiece box which was kept closed but unheated (it has a heater).
So, at the end of the night, as we're packing up, we decide to throw my son's Star Blast on to the Perseus Double Cluster. The Pan 24mm fogged up almost instantly when it came out of the box. The XW20 stayed clear, even though it had been exposed to the sky all night!
I have two thoughts about this.
1. The mass of the eyepiece contributes to keeping it thermally stable and therefore bigger heavier eyepieces are less prone to dewing.
2. The *insulation matters.* In other words the design of the XW with no exposed metal and a cup that shields not just light but tends to create an "overhang" over the glass is probably a thermally efficient design.
If this is true, it is a design factor that I had not thought of.
I wonder how a variety of eyepieces would fare in a dew-over contest. I'll probably post this one on Astromart as I'm interested in a variety of comments.
regards
Greg N
Posted 09/26/2009 07:04PM #1
Hi,
I had the same problem with the 13mm and 7mm T-6 Naglers, they fogged up almost immediately after I placed my eye to use them.
Not sure why, but it was a constant problem for me.
Posted 09/26/2009 07:43PM #2
The big overhanging eye cup of the XW will definitely reduce the infrared heat loss to the sky and slow down dewing.
Moving to S. California or Arizona is your best course of action. wink
Mike
Posted 09/30/2009 05:21PM #3
My XW20 is almost impossible to fog. My 26mm T5 Nagler is very difficult to fog as well, probably due to its large mass. Every one of my Vixen LVW's (5, 8, 13, and 22 mm) will fog in a matter of minutes, or if you just look at them funny. I keep them all in an unheated foam lined eyepiece box. This is in Houston, TX.
-Robert Harris
