one comment and one question
Started by [email protected], 09/30/2008 06:06PM
Posted 09/30/2008 06:06PM | Edited 09/30/2008 06:17PM Opening Post
I thought I'd share an observation from this past weekend, when I had the chance to use the 31 nag alongside my 35pan in a 16" f/4.5. I remember seeing the 31 a couple years ago, since its memorable balloon shape stuck in my head. I've changed eyepieces many times over the years, but the 35 Pan has had a place of honor in my case--never to be replaced.
I compared views of the 31 to the 35 while looking at M31 and its companions, and the Double Cluster. I did find that the 31 nag did frame the objects better, and there was indeed a slightly better contrast and sharpness to it. However, given the cost, I don't think I'd ever be upgrading my 35 pan simply to view three or four objects in a slightly larger fov. It was nice, mind you, very nice...but not worth another 300 dollars. So my old friend stays in his case, waiting to be called upon again....
On another note, I'm wondering what others find are their most common magnifications? I have 24.5 Meade SWA's (old, old style) in a Denk bino with a dual and a single power switch, so that one pair gives me 6 different mags. I really noticed how introducing the single element for more power darkened things up. There was a time when the transparency and seeing allowed real power on Saturday night, and I tried to keep track mentally which two powers I was using the most. Turns out, it was the middle setting when the single power switch was not engaged, and when it was in. That meant that I was looking at the globs and nebulae at 150X and 349X most of the time. Crunching the numbers on what a pair of 16t5 nags would do, I get 149X and 390X, however, the apparent field is much greater of course. That means my 24.5's will retire to their cases to be called upon for low power views, otherwise I think the 16's will be the main eyepieces. That got me thinking what other people like, and is why I'm asking that now.
Cheers,
Guy
Denk II w/nags junkie
Posted 09/30/2008 06:17PM #1
The 31mm Nagler is still less expensive than the 17mm Ethos! grin
Posted 09/30/2008 06:46PM #2
Guy,
I use a similar set-up on a 14.5" Starmaster but I have the 2-arm power switch for SCT's (from a prior scope) which provides multipliers of 1.4x, 2.3x, and 3.5x in the Denk binoviewer.
A pair of 24mm Pans give me 92x, 152x, and 231x. A pair of 17mm Stratus give me 130x, 214x, and 326x.
I always start with the 24's at lowest power to assist locating an object in case my GOTO is not on the money. 90% of my viewing is done at 92x and 152x. When I want to look deeper I use the 17's and very rarely a pair of 13mm Stratus.
In all cases the highest power setting for any EP pair is generally too dark to be of any advantage. Also, seeing conditions in central NC seldom lend themselves to high powers.
Jim
