Philip Imbrogno
Elephant Trunk Nebula
Panning With ES100 14mm
Started by Rod Kaufman, 04/21/2012 11:27PM
Posted 04/21/2012 11:27PM Opening Post
Friday evening at the LAAS site was a real treat. Excellent transparency with very good seeing(running 500+ on Saturn)combined for exceptional views of the galaxies of springtime.
My sky quality meter was showing 21.67 at the zenith and that's probably around tops for Lockwood Valley. I had my paracorr in place with a 14mm ES 100 degree eyepiece in my 16" f4.5 dob and I could easily discern 13.5 magnitude galaxies without difficulty. Both the 14mm ES eyepiece and my 10mm Ethos showed structure and mottling in a number of brighter galaxies so I decided to pan the Virgo cluster(s). Verdict: panning Virgo with a 100 degree moderate focal length eyepiece in a reasonably sized dob is something you've just got to experience under dark sky conditions. The extra amount of apparent field of view in seeing cluster after cluster of galaxies in Virgo is definitely worth the price of admission. The eyepiece is well corrected and although you see some minor coma with a paracorr near an edge of a field of view in a fast dob, the extra amount of AFOV enables the observer to take in so much more compared to lessor fields in more conventional eyepieces. The ES 14mm is comfortable to use and it's not a problem to take in the field of view without craning your neck in order to do so.
If you've got a decent sized dob and access to dark skies, load up a 14mm 100 degree ES or an Ethos equivalent and blast thru Virgo. You're in for a real treat!...
Posted 04/27/2012 03:14PM #1
I agree! Last night I used my ES 14mm 100° eyepiece on the Virgo cluster for the first time. It was great for zipping up and down Markarian's Chain without getting lost. I was skeptical about the need for a 100° field at first, but am enjoying it a lot more than expected.
