George Golitzin said:
Does Greg Nowell's dioptrx trick work on the shorter focal length XWs? I'm looking hard at the 14mm, but I will need astigmatism correction on it, unfortunately. At f/5, anything above my 11mm Nagler seems to need some help. It looks like the smaller focal lengths have pretty much the same mechanical assembly at the eyelens level as the longer ones...
Maybe Greg could comment...
Thanks!
George
I'm glad s.o. has read my article! Surely I must be famous. Like Roland???
1. Short answer: It won't work. The XW30 and XW40 have different diameters from the rest of the series.
2. Longer answer: If you disassemble the dioptrx a bit, "possibilities arise." The lens assembly comes out of the lettered ring. Some caution is advised as the inner most ring can unscrew and release the lens completely. But in the end there is a ring in side the ring which can hold the lens, and if you play with it you'll see that this asssembly can actually hang readily (but not pop on) on the inner metal lip of the Pentax. It works well enough that you could use the eyepieces that way, but you'd have to grab the lens as you switch positions on the scope or, if other users are around, if you walk away from it. Most folks wouldn't expect something like that to fall off, so letting it hang on the eyepiece would be a solo practice. It would work like a monocle that you pop on as needed. You would be sacrificing the rubber eyecup which is a big part of the satisfying ergonomics of these eyepieces. It might be possible to put a soft spacer on the inside of the TV ring to make it actually hold with some pressure. It certainly requires thought in the presence of the eyepiece and the Dx so you can try to figure it out.
3. You mention f/5 and all I will say about that is that the XW is most-frequently-sold by dob guys because they don't like the field curvature this eyepiece gives at short scope focal lengths. The XW20 is the other eyepiece that dob guys typically don't like, although my friends think they do OK, so maybe it's a regional cultural thing. I use all the Pentaxes at fls of 6.5, 8.1, and 11 and think they're the cat's meow. But the curvature thing is something to consider before spending a lot of dough on a 14mm. I'd like to say Pentax can do no wrong but a lot of fast Dob owners have rebelled at the 14 and 20mm. I assume this would apply to fast refractors though mine is dandy at f/6.5.
regards
Greg N
