Wizard Nebula
Planetary Eyepiece Info Needed
Started by chuck731, 10/26/2005 07:20AM
Posted 10/26/2005 07:20AM Opening Post
I'm thinking about purchasing a better planetary ep for my Orion XT10, 4/7 dob but don't want to break the bank.I was thing about the Antares Elite Plossl series but heard pro's and con's about him. I thought I would post this and see what you guys come up with. Two head are better than one. I welcome everyones advise and outlooks.
Thanks..Chuck
Posted 10/26/2005 05:17PM #1
For an inexpensive planetary set, the UO Orthos are hard to beat. Even new they won't break the bank. Do realize they have short eye relief though.
Posted 10/27/2005 12:19AM #2
I have used a number of the Antares Elite plossls, and still have the 20, 15 and 10mm versions. I found them to be very good on both planets and DSOs, similar in performance to a couple of Antares orthos but with a wider FOV. The 10mm in particular was significantly better than the 10mm Sirius Plossl that I first used at that focal length.
More recently I have shifted to Pentax XLs and Nagler T6s in the shorter focal lengths. While the Elite Plossls don't give as wide a view or, in the short focal lengths as comfortable a view (compared to the 20mm eye relief of an XL), in terms of sharpness and contrast they hold up pretty well.
Jeff Bennett
Posted 10/27/2005 12:46AM #3
When I think of planetary viewing, I think of higher powers. A 12mm in your scope will provide in the neighborhood of 100X. That's not very high on the scale. 10mm is not that much more, maybe 120X. I would think you're going to need something in the range of 7-5mm for better planetary views.
Personally I detest tiny little eyepieces with really tight eye relief so when it comes to the shorter focal lengths I tend to use a barlow on my 15mm and 12mm. I have also just ordered and not yet received one of the 66 degree WE9mm which I beleive is a Synta product. Also available from Orion as the Expanse line I believe. Folks here have spoke highly of it so I thought I'd give it a try. Price was also very right.
I also have one of the now discontinued Apogee 7-21mm zooms which performs respectably enough for the $50 it cost. These might be hard to come by now.
dan
