Philip Imbrogno
Elephant Trunk Nebula
Re: Blackened lens edges question
Started by dhilts, 08/18/2012 05:22PM
Posted 08/18/2012 05:22PM | Edited 08/18/2012 05:25PM Opening Post
I am of the opinion that most of the time it is inconsequential.
Blackened edges are suppose to reduce the amount of scattered light from the lens edges. In a properly designed eyepiece, the lenses and their holders should be sufficient diameter to pass the light rays without any light hitting the edges. There shouldn't be any scatter. A properly sized and positioned field stop is important to reduce the amount of stray light entering the optics and will help to prevent scatter.
Yes there may be times when a bright star or other object is right at the edge of the field of view and creates some glare that makes it pass the field stop. Under these circumstances the whole field could be awash with stray light, not just the edges of the lenses. I doubt that you would notice the difference between an eyepiece with blackened edges versus one without under these viewing conditions.
Point your scope at the daytime sky while you look through it. Can you see the edges of the eyepiece lenses? That will give you a pretty good idea how much you will see any reflection of scattered light from the lens edges.
Just my 2 cents worth.
Lots of folks will disagree.
dan
