I like pure alcohol, or 93% or better for cleaning EPs. Acetone will attack plastic, 93% alcohol will not unless it is painted with an alcohol based paint. Pure alcohol is a bit more aggressive in this respect and should be used only if you know the material around the lens is not effected, it will remove some paints that the 93% does not touch.
You can get the 99.4% pure at an electrons or electrical supply house. The 93% can be found at a local drug store and is much cheaper, the other 6-7% is just distilled water so it is fine.
I also recommend using specialized cleaned patches or cotton balls and white untreated Kleenex. I use some cleaning tissues I ordered that were recommended by Roland at AP.
