Haven't tried it myself. One minor issue I can think
of -- there will be considerable torque from
the weight of the eyepiece + lever arm of the
Powermate. Stuff might happen -- rotating tubes
will want to rotate. On refractors and Cass scopes
the diagonal will want to rotate in the focuser -- or
the focuser will unscrew from the scope --
ending up with the eyepiece pointing at the ground
-- probably the safety under-cut on the 2" barrel will
catch the setscrew and save the eyepiece.
On Dobs any flexture in the upper tube will be
made worse by the large weight far off-axis.
OTOH if you've got a beefy focuser strongly
attached to a rigid tube, and very strong set screws,
you should be fine.
you should be fine.
