RICHARD COFER
reducers - wider fields
Started by opticsguy, 04/08/2007 04:08AM
Posted 04/08/2007 04:08AM Opening Post
Needing a wider field of view than either a 56mm plossl or a 41mm Panoptic can provide. Are there any QUALITY reducers that could give me a wider field of view? Are there other options? I assume longer focal length eyepieces would require more than a 2" focusing unit.
41mm Panoptic provides a 0.6 degree FOV with 2.4mm exit pupil at 105X.
Thanks for any ideas and suggestions.
Posted 04/08/2007 11:07AM #1
You might tell us a bit more about the scope. It seems to be a 10 inch F/17 so I am guessing a Mak or Classical Cassegrain...
jon
Posted 04/09/2007 03:19AM #2
You could always find a friend that owns a large schmidt cass and borrow his reducer to try it.
PS - that friends wife says you don't NEED another telescope toy. =;^)
Clear, sunny skies.
Tom Masterson
Coronado-Lunt-Daystar Solar Filters forum Moderator
Posted 04/13/2007 02:56AM #3
My original question pertained to the 10" f/17 refractor currently under construction. Seems everyone got distracted about the 9" Celestron.
So, I will again ask about useing a reducer to get wider fields of view with THIS refracting telescope. It appears the best choice is the 55 plossl, 41 pan and the 31 Nagler all resulting in a 0.6 degree field of view, however, the plossl has an 3.2mm exit pupil versus Nagler with 1.8mm exit pupil.
Would a reducer still provide wider AND sharp views? Should I chase down a longer FL eyepiece and use a larger focuser (2.7" or 4")?
