SCTs and the 41mm Panoptic
Started by TheDesertSage, 12/28/2006 03:50AM
Posted 12/28/2006 03:50AM Opening Post
Hi - Does anyone here have any experience with the 41mm Pan coupled to a 10" or larger SCT? I am contemplating the purchase of a 41mm Pan, but would like to hear of others' experiences with the EP first. I had 27mm and 35mm Pans in the past. They were very sharp and comfortable to look through, but the pincushion distortion really bothered me, so I sold them. Has anyone evaluated pincushion distortion in the 41mm Panoptic? Is it better, worse, or about the same as other long EFL eyepieces in the Panoptic line? Thanks in advance for any advice! - Chuck
Posted 12/28/2006 06:32AM #1
I'm not an expert Chuck but I have 'test driven' both a 27mm & 41mm Panoptic in a C11 and 12" Meade LX200. The pin cushion distortion isn't as bad in the 41 but it is there at the very edge. If it bothers you in the 27 & 35 I suspect your eye will be drawn to it while using the 41. Just as a thought you might see if you can try out the 40mm TMB Paragon.
Clear Skies, Bill
Posted 12/28/2006 08:37AM #2
If you are using an SCT you should be looking at the Axiom or UO Mk 70 series instead of the Pans, and saving some money in the process. Axioms are great at f/8 or slower with much less pincushion than the Pan design. I use a 34mm Axiom in my MCT and it's really great in a long focal ratio scope. Also, you might want to consider a 2" Siebert Observatory. The Pan design has lots of pincushion distortion to allow sharp stars at the field edge in fast scopes. With an f/10 or slower scope, you can greatly reduce pincushion distortion and still stay sharp at the edge with some other designs. No need to use an f/4 Dob EP in a Cassegrain scope. Use a Cassegrain friendly EP in a Cassegrain scope.
Phil
