Jay Messeroff
Lunar & Solar Transits
Sky-Watcher Ultra Wide Angle Eyepieces
Started by adams61, 06/14/2010 01:09AM
Posted 06/14/2010 01:09AM Opening Post
I just now started seeing advertizing for these and just wondering how good are they at the price I have seen between 33-35 dollars apiece. Has anyone used these?
Posted 06/14/2010 08:48AM #1
These appear to be the generic Synta 66 degree UWA's that have been around for several years. Orion sells them as the Expanse, Antares put a fancy aluminum barrel over them and called them the W70 series. At one time or another I have owned all of them.
The 6mm and the 9mm are both negative-positive, i.e. they have a Barlow like Symth front section and a magnifying rear section. This allows them to have quite reasonable off-axis correction in a fast telescope. I have owned 2 of the 6mm, they had some glare issues but mostly just seemed soft for a 6mm.
The 9mm is the one to get. I still have one of these. They are quite well corrected off-axis in a fast scope and I measured the effective AFoV at 70.5 degrees. Some complain of Kidney Beaning, this happens to me during the day but not at night. It's decent performance in a fast scope has earned this eyepiece the nick-name: Poorman's Nagler. IME, it deserves that name. A similar design, I keep mine around even though I have a 9mm Type 6 Nagler.
The 15mm and the 20mm are again similar. These are simple eyepieces, 4 or 5 elements and seem like they are based on the Erfle. In a slow scope, F/10 or slower, they perform like an Erfle, quite sharp across the field of view. In a fast scope, they perform like an Erfle, that is to say, sharp on-axis, a good deal of astigmatism off-axis.
So, depending on what sort of scope you might use them in, they can be quite good or not so hot. At $30-$35 they are a nice way to get a taste of widefield eyepieces without spending a bunch of money. My suggestion is to try the 9mm. If you have an SCT or slow refractor or maybe an F/8 Newtonian, try the 15mm or the 20mm.
