Summer observing sessions in June can offer some impressive benefits and some significant drawbacks. I can drive up to Mt Pinos on Tuesday evening after work during new moon and set up and still have time to relax until nightfall. OTH, nightfall takes another three hours till around 10:00pm until it's really dark enough to start some serious observations. Although I've recently renewed my membership with the LAAS, I haven't heard anything from them as yet so I decided to take a chance at nearby Mt Pinos instead. Basically, it's still zooland up there, even on a weekday. The poor guy next to me trying to take dsrl images was so upset with incoming that I thought he might call in an airstrike but that's the risk you take when dealing with what you find up there once you arrive and setup. Nevertheless, I was able to run some checks on my newly acquired Solomark filters:
http://www.amazon.com/Solomark-Telescope-Moon-Skyglow-Filter/dp/B00OXKG1XS/ref=sr_1_9?ie=UTF8&qid=1434600882&sr=8-9&keywords=solomark+filters
and:
http://www.amazon.com/Solomark-Telescope-H-beta-Hydrogen-Filter/dp/B00OXKGHUA/ref=sr_1_16?ie=UTF8&qid=1434600882&sr=8-16&keywords=solomark+filters
First, with my 16" f4.5 dob and a 9mm ES 100AFOV eyepiece in place, I found the moon and skyglow filter to actually perform as one might expect it to do. That might be a obvious expectation but the one that I got with my Zhumell filter kit was worthless. I tested it on M81/82/ 57/ 104 and the ringtail in Corvus. Here's what to expect: in deepening twilight, the filter actually works. In other words, while the sky is still not dark but enough to begin early observing, or perhaps if the moon is present, the filter will enhance the contrast to the degree that the details evident are better with the filter than without it. However, as darkness falls and the reason you've driven to a dark sky site becomes evident, the views without the filter in place become clearly superior. The resolution of detail in the galaxies are discernible with and without the filter in place but under dark sky conditions, the views without the filter are better. Still, I feel the filter has its place in my observing kit, and at its current price point, it's a good deal.
Next up, the solomark beta filter. First, I have a bias against beta filters. I don't like 'em. Why? Because they're useful on only a limited number of objects and they really darken the field of view to the point that it can be a bit frustrating using them. I tried the filter on the cocoon nebula in Cygnus. About all I can say is that it appears to work and I'll keep it for future use on the horsehead which is about the only time I'll probably use it again. Still, at it's current price point noted above, it's a reasonable addition to the observing kit and you'll have it when you need it when you hunt horses...
and:
