Just in case anyone's interested, here are some rough summary statistics on what was posted in that incredible 3 most used eyepieces thread. With multiple entries, I usually selected only one set of 3 eyepieces, and that was for the dob... (personal bias). A couple of smaller refractors got dropped entirely if the longest focal length was something short, e.g. only 9mm. Clearly averaging choices together is fraught with problems, but here are the results anyway!
Average focal length for 3 most used -- 27, 14.9, and 8.2
Median for 3 most used -- 26, 14, and 8.8
We can use the results to pick a gold winner set!
At the high $$ end, it looks like a 26mm Nagler, 14mm UWA or Pentax XW, and 8.8 UWA!
Or a 27mm Panoptic, 14mm Pentax, and 8mm Radian.
For much less money: 26mm Meade Series 5000, 15mm Vixen or 13mm Stratus, and a 9mm Expanse or 8mm X-cel.
Obivously one's choices depend on the scope's focal ratio, tolerance for sky brightening, and the type of objects being viewed, but the choices were surprisingly similar and largely independent of scope focal ratio.
By the way, the SDs were 5.6, 3.1, and 2.4 Shows that there is definitely some variation. (This is partly because some picked a 30-35mm 1st then jumped to the 20-24 range which was other people's first choices)
Using ± 1 SD, we'd have about 21-33, 11-17, and 6 - 11 which reflects the variation and overlap in choices.
