Tightening up BO/TMB 6mm
Started by jonisaacs, 08/15/2008 08:52AM
Posted 08/15/2008 08:52AM Opening Post
Hi: The inner workings of the front section of my 6mm TMB/BO Planetary will not stay tight. Each time I tighten it, it is soon loose enough to rattle.
There are two sets of threads, one for the lens retainer ring, one that threads the front lens assembly into the barrel. It seems like the threads needs some lubrication but that would be pretty scary as it would certainly work it's way to the optics.
Any thoughts or tips?? Anyone else with this problem??
Thanks
jon
Posted 08/15/2008 01:36PM #1
Having the same problem with my 6mm BO/TMB it rattles a little I though about putting a little super glue on it but know if thats a good ideal.
Posted 08/15/2008 05:59PM #2
You could lock the ring once tightened with a little dab of non hardening glue, like RTV. You can use a tooth pick to apply it to the area of the ring and thread, just a tiny dab in one spot so that it can be broken or removed if needed in the future. This should hold it fast but allow a small amount of contraction or expansion.
I would think this must be due to temperature change. Tightening while warm would probably make it loosen when cold. But if you tighten it cold, it would probably pinch the lens when hot.
