Mark Eby
M33 Triangulum Galaxy
UWAN 16mm is only 14mm
Started by Birder, 09/28/2022 07:12PM
Posted 09/28/2022 07:12PM Opening Post
Hello, recently I made some comparisons of various EPs in my binoviewer and found out that TS UWAN 16mm is not 16mm at all!! It's exactly 14mm, I can place an ES14 in one side and a TS UWAN 16mm in the other side and get a sharp image, they give exactly the same enlargement. The UWAN has a slightly wider field though. I find it amazing that such an eyepiece can be manufactured for years with so misleading specs, why hasn't it been changed? Many people must have detected that before me!
Now I wonder, if UWANs from other manufacturers than TS Optics have the same problem? Nirvana, Lacerta and others look exactly the same, I suppose they are identical, just with different brand names. But the UWANs from Williams Optics look different. Does anyone have experience with these, are they any better than TS UWANs, which have a tendency for blackouts, if you want to see the complete field, and are they actually 16mm or 14mm as the others?
Thanks for your time,
Henrik.
Posted 09/29/2022 03:57AM #1
Henrik.
Well, there's more than one ES 14mm model available: the ES 14mm 82AFOV and the ES 14mm 100AFOV. I have the latter and not the former and I guess the 82AFOV is what you're referring to in your post. I suspect the ES eyepieces have the correct focal lengths while the 16mm is off but it's not too surprising to me since I've seen focal lengths misstated before, especially in zoom eyepieces.
Posted 09/29/2022 04:45AM #2
Yes Rod, it's the ES82 degree I'm referring to. I posted this on Cloudy Nights too, and there Don Pensack told that Stellarvue has the same UWAN, but marked as 15mm. I think you're right, that the ES14 is actually 14mm. In comparison with 2 16mm EPs I have, Meade and Masuyama, UWAN and ES give remarkably more magnification, there must be more than 1mm difference.
