Philip Imbrogno
Elephant Trunk Nebula
what to buy
Started by tpsmith17, 07/22/2008 04:21PM
Posted 07/22/2008 04:21PM Opening Post
i have just purchased a celestron c11 and was wondering if you wanted to begin a collection of truly top quality eyepieces where and what is a good place to start. i have the basic sets of eyepieces with the scope but if one were purchasing the first high quality eyepiece that would give you a little of the best views for planets and dso's knowing it would not be the end all what would you recommend? mainly interested in the mm size that would give a little bit of both.
know this is impossible to answer but trying to start somewhere.
thanks
Tom
Posted 07/22/2008 04:32PM #1
If in doubt, buy Televue.
Rolando
Posted 07/22/2008 05:05PM #2
Tom: Roland has given some great advice, sooner or later most of us seem to end up with a case full of TV eyepieces. Which ones and in what order... A few simple thoughts:
- A F/10 scope is quite forgiving of eyepieces, basic eyepieces like Plossls are well corrected to the edge at F/10, (though the scope design itself may have issues.) So, when choosing eyepieces, one has to decide if you want to build a general purpose set that will work with any future telescope...
Personally I recommend building a set that will work nicely with any scope, fast or slow. To me, that means, Naglers number one and Panoptics number two. If you want to have a set that produces those pin-point to the edge stars in that 16 inch F/4.4 Newtonian that might be in your future, those are the eyepieces that will make it happen.
- As far as a first good quality eyepiece, you know there will be more. Since simple eyepieces work well in a C-11 for planetary viewing, I would look at something that was nice for DSOs, maybe a 24mm Panoptic or some such...
jon
Posted 07/22/2008 07:36PM #3
I find it easy to echo the majority here.
When my wife and I bought our first scope (NS11) I muddled by for a few months with the starter kit. My first premium buy was the 24mm Panoptic. Next was the 13mm Nagler T6. Now I have an eyepiece case full of mostly green lettered eps, but almost every evening starts with the 24 Pan. Most nights it and the 13 T6 spend 90% of the time in the diagonal. They wowed us when we first got them and continue to be our favorites. We use them in our other scopes too, but they are our favorites in the big SCT.
Jim in Texas
Posted 07/22/2008 08:14PM | Edited 07/22/2008 08:39PM #4
I have to echo what others have said - you can't go wrong with Televue Panoptics & Naglers. You may end up going through a dozen scopes searching for the right one(s) for yourself - but a good set of eyepieces are more likely to stay with you. The old Vixen LVWs compare very favorably to TV Pans and are cheaper. Personally, I find the 13mm LVW to be the most comfortable eyepiece I've ever used - no blackout issues no matter where your head/eye is.
You should, if at all possible, try before you buy, or at least solicit opinions from other C11 owners as to how they like their eyepieces. Some may not come to focus in your scopes for all you know. Some may have very critical head placement requirements and produce "kidney bean" & other blackout issues.
Attached is a screen grab of an excel sheet setup to calculate mags, TFOVs, exit pupils for many high-end oculars(eyepieces) for your 11" f/10 SCT.
A few other things to keep in mind are:
Weight - is the eyepiece going to be too heavy for my OTA/mount combination?
Do they have enough eye relief for you?
Are the exit pupils optimized for the objects you are going to observe? (for example, I find that a 2mm exit pupil really gives me the most detail on galaxies in my 11, 16 & 20 inch dobs).
You can get TV specs from
http://www.televue.com/engine/page.asp?ID=144
A few of them - the 41, 35 Pans, the 31, 25 Naglers - can be quite heavy. Eye relief the recent versions of Naglers and most Pans (15mm Pan being an exception, I've read) are more than adequate for most people.
In the 19-22mm range you mention, I find that my 20 T5 Nagler spends A LOT of time in my focusers. It's shorter eye relief than the 22 nagler, but much lighter and slightly better corrected than the 22mm in the f/4.5-f/5.4 scopes I use. However, the 22mm is no slouch! I love them both...
For planets, you may want to consider a simpler design like orthoscopics - the UO 9mm ortho has adequate eye relief and much fewer glass surfaces than the 9mm nagler... and much cheaper, too;
http://www.universityoptics.com/eyepieces.html
The 9mm would give you 311X - which may be too much magnification unless you have decent seeing. But they're cheap enough that you could get a 9 & 12.5 Ortho for less than just about any new panoptic.
K. Michael M.
thanks
Tom
kmichaelm's attachment for post 123747
Posted 07/23/2008 08:56AM #5
Like many, I have a fair few Televue eyepieces and count the 24 Pan and 13 T6 Nagler among my most used...I am also quite fond of the Pentax XW line. I have not had experience with a C11 but in my reflectors and refractor would compare the Pentax glass favorably with the Televue...both top shelf!
Posted 07/25/2008 04:32AM #6
13 nagler is first premium and it is my bread and butter EP. 9 nagler is my second premium. My 3rd will probably be a 24 or 35 pan.
Posted 08/10/2008 02:26PM #7
Try Baader Hyperion and Eudiascopic. The Eudiascopic is basically the same as the old Ultima series and they work great at f/10. The old Axiom wideangles are hard to beat at f/10 as well. At least as good as Televue at f/10 and much cheaper. I have Ultima, Axiom and Star Splitters as my premium eyepieces for my 150mm LOMO Mak-Cass, and it's pretty much the optical equivalent of a $5000 refractor (1/8 wave optical performance) and soundly beats a C11 I compared it to in visual sharpness, if not brightness. It has no tendency whatsoever to decollimate in transport and does not shift when focusing....but it was sold as a pro level scope. Any eyepiece good enough for a big LOMO Mak-Cass is more than good enough for a Celestron or Meade Schmidt-Cass with their typical 1/4 wave optics and tendency to decollimate in transport.
Also consider the eyepiece turret from TEC. It works great in any refractor or CAT scope with a 2" visual back and has a 1/10 wave mirror for $500.
TeleVue will repair their eyepieces, and this is the main reason to buy TeleVue, if you are hard on eyepieces. They hold their value for resale and are easy to sell. I am easy on eyepieces, I needed bino pairs, I needed all 1.25" EP's to be parfocal for the turret, and I have no interest in reselling. Ultima and Axiom were a much better deal in a scope of focal ratio 8 or longer.
FWIW, EP's that are not parfocal are hard to use in a Schmidt-Cass as focus is harder to find than in a refractor. You'll be spinning your focus knob a lot and putting up with image shift unless you lock mirror and install a Crayford focuser. I just spin my turret and my Ultimas are in perfect focus.
