Why would'nt you clean an eyepiece?
Started by proteus, 06/30/2007 02:21AM
Posted 06/30/2007 02:21AM | Edited 06/30/2007 02:37AM Opening Post
This subject comes up over and over again. Not only here but at many sites. Many want the powers that be or manufacturers to give the exact how to to clean optics. On the other side of this argument the experts don't want to tell you because of responsibility of damage or you're not trained to do this. I respect this.
This said, I've seen many folks clean the top lens of an ep with their tee shirts while at the mount. I'm sure many of you are guilty of this. Please don't do this and I'm not advocating doing this, just saying I've seen it done.
Every used ep I've purchased had goop on the top and bottom lens. You can't tell me this doesn't affect viewing. It does affect viewing.
So what's this big fear of cleaning optics? You clean your glasses don't you?
Blow off the big chunks with a duster can. Get some cleaner and cue tips and view through a clean ep. It's your ep isn't it? Most Magnesium fluoride coatings are pretty tough, not all, and testing at the edge is a good practice, but what do you care, it's your ep and you want good viewing don't you?
The manufacturers clean them, why shouldn't you? Sure, multiple cleanings can reduce the coatings, but what's the use if you're looking through a blob of goo? Enjoy the views through a clean piece of optics.
If you're worried about resale, then don't sell it and keep it. If you screwed up and damaged it or scratched the coatings, then keep it and maybe you'll learn from your mistakes. Maybe learn on a cheap ep? Sooner or later optics need cleaning no matter who owns them.
Simple lesson, don't rub chunks of dirt or dust across the surface.
Sure, using a cue tip and some sort of cleaning agent (isopropyl, ethanol, acetone, breath) will displace the goo to the outer lip area of the lens, but at least it's out of the field of view for the most part. Rub that stuff back onto the surface and you will scratch it unless you followed step one, blow off the chunks.
I've hinted and told you about vacuum cleaning the chunks off and using vacuum probes to pick up lenses out of an ep housing. I'm remiss for not actually showing you how to do this. Until I do this, clean the outer lens surfaces and enjoy your clear viewing.
If you've got lint or big pieces of dirt inside, then pm me and I'll write to you how to get the lenses out in order with a vacuum probe you can make. You all have a vacuum cleaner I hope?
I work in a clean room. One of the lessons and books we have to read is clean room operations. One method of working in a clean environment is not in a clean room at all, but under a microscope. Anyone with a microscope can produce the same results as in a clean room. You just need vacuum, a probe (looks like a syringe needle) and a microscope, one lens at a time after its seated in the ep housing. You suck the lint or dust out with the vacuum probe and don't have to clean the lens. I use a stereo microscope since you can put bigger stuff under it.
I will never tell you to clean optics without a microscope. If you don't have a microscope, leave the "interior" surfaces alone. Me personally, I wouldn't clean the outer lenses without a microscope, but don't let that discourage you from cleaning your top and bottom lenses. Blow off the chunks.
Ok, let the flaming begin. Sometimes I hate to hit the "post" button. Joe
Posted 06/30/2007 03:38PM #1
No flames here Joe, I agree with the gist of the post.
Many people would have problems taking apart and the reassembling a complex EP on their desk, much less cleaning the lenses to perfection.
The two outer lenses should be all that need to be touched if the EP was made by a quality maker and if it has never been disassembled. The dust inside is usually not enough to cause concern unless it was opened.
The coatings on good EPs are indeed pretty tough, as long as there are not abrasive particulates on the surface when the lens is cleaned. So for sure you need to blow off or vacuum off these particles before any lens cleaner is applied.
[COLOR="Red"]I know of a man that takes a handkerchief out of his pocket (snot free I can not state) and then wipe off a DOB mirror with it dry! 8O Actually scrubbing it with it to remove spots! Now this I do not recommend. 8)[/COLOR]
Same with an EP lens. If you do not have the proper things with you to clean it in the field, then don't! Use another EP or just use it as is until you can get back home and properly do the job. grin
Posted 06/30/2007 04:17PM #2
Mostly what I see on my eyepieces are fingerprints and other oily residue. I have no qualms about cleaning them in the field. I do blow them off first and/or use a brush to get any loose particles off. Then if it's just fingerprints, I will exhale on the lens (hope that doesn't cause any strokes out there) and wipe it clean with a lens cleaning tissue. If it's something more resistant like sap, I may use some lens cleaning fluid or alcohol. I have some eyepieces that have been cleaned this way for over 15 years, and I don't notice any deterioration of the coatings as a result. Okay, don't buy an eyepiece from me it you're skeptical.
On another note, a few years ago I got a used 22mm Panoptic that had dirt on the inside. Having taken apart barlows and other simple eyepieces, I promptly took it apart when to my horror I realized the whole thing was falling apart in my hands, numerous lenses, spacers, and all. I had no idea how to get it all back together. First I paniced. Then I sheepishly called Televue to see if I could send them my newfound collection of eyepiece parts. Believe it or not they had a customer service person who could actually guide me through the whole assembly procedure. I was amazed and greatly relieved. I probably wouldn't do this again, but I did get the crud out of it.
Posted 06/30/2007 07:57PM | Edited 06/30/2007 09:22PM #3
Here's your ep cleaning kit parts list. Let's keep it cheap. Print this out since it's long winded.
From McMaster Carr you need these items. The part number for the "solid rubber cork" is not the size you need, it just gets you to the right page on their site.
http://www.mcmaster.com/
Solid rubber cork - 9545K51, size determined by your vacuum cleaner hose.
Surgical tubing - 5234K76, get black color since it looks cool and same price as amber. Not cheap per length, but buy a long enough piece to get your vacuum cleaner away from you because of the noise. Maybe stick the vacuum cleaner in a closet next to you. I hate noise.
A (1) inch long piece of 1/4 inch O.D. metal tubing. 1/4 inch copper water line's cheap.
Now you need some magnification. Head band magnifier with an extra eye loupe.
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_612263_612263
Vacuum pickup probes are next. It doesn't matter where you find them, just keep it cheap.
http://www.howardelectronics.com/virtual/images/3_8,1_4,1_8,S3_8,S1_4,S1_8.jpg
http://www.howardelectronics.com/virtual/vacuumcups.html non-esd silicon set for $12. Gives (8) cups to work with. You still need to buy the needles separate so call them.
Now you have your parts so what's next. First, drill a 1/4" hole in the rubber cork. Next put your metal tube in the cork. Then push your surgical tubing over the metal tube. Cork is now ready to push into your vacuum cleaner hose. Make sure metal tube fits tight in rubber cork.
Now you have a vacuum pickup system that's pretty powerful.
So you want to get the nasties out of or off of your eps. Find a clean area to work, no, not a clean room. Don't push this thread to that discussion. Remember, magnification and vacuum gets you there.
If taking an ep apart, unscrew the clamp ring(s). Put the ep top up or bottom up, depending on how it comes apart, on your bench. DO NOT HOLD IT IN YOUR HAND. Insert a vacuum probe into the surgical tubing. Use the largest tip cup size that fits over the lens. Try lifting the lens straight up moving it just a little. Use two hands to hold the surgical tubing. Don't pull the lens all the way out until you see you have a good grip on it with the vacuum. It's very important to test the suction on the first lens, usually not a problem though.
So now you see you can hold the lens without touching it with your hands. Don't squeeze the surgical tubing or you'll break the suction and drop the lens. I do recommend "powder free" finger cots or surgical gloves though. Invariably you may end up needing to handle the lenses with your fingers and bare fingers are a no no, so don't even think about it.
What you do next is up to you. You can clean the lenses while holding them with the suction using cue tips and solution. This part is where you can make a mess and I don't recommend this unless you have soft clean room towels and can remember which side is up on the lens. Beginners can screw this up very easy. Most lenses on the inside of the ep are clean and all you're doing is sucking up dust or lint with your probe. You don't have to make physical contact with the lens. One thing I've noticed on most lenses is the clamp ring or separator will leave a faint ring in the coating and you can use this to identify which side is up, but not always. Lightly blow the lens with a duster can before re-inserting. Don't tip a duster can or vapor deposits will form on the lens. Blow them from a distance.
I number metal tins to put my lenses in. You can put them on lens paper or whatever that's clean. Number the papers with a sharpie (1) thru whatever. Now that you're holding the lens with your vacuum probe suction cup, you move straight over to the first clean paper and pinch the surgical tubing. This releases the lens onto the paper. You pick them up the same way.
Let's say you're not taking an ep apart and want to just clean the outer lenses. Take one of your vacuum probes and pull the suction cup off the end. Find something like a plastic coffee stirrer stick or small diameter plastic tube and slip it onto the needle. Test it to make sure it doesn't melt with acetone. Cut it short. Now you have a plastic vacuum tip to suck up around the lip edges. Put a drop of acetone or ethanol on the lens and quickly, I MEAN QUICKLY SO IT DOESN'T FLOW UNDER THE LIP, suck up the solution at the "outer edge" of the lip, not in the middle. I prefer ethanol for this because acetone evaporates too quickly. You'll be amazed that the lens will be almost perfect without even touching the surface. Now all you have to do is lightly swab the lens with your breath and a cue tip. Don't rub hard.
I hope you folks can follow this long thread. Good luck. Don't handle the lenses with bare fingers. Use the suction probes instead. Finger prints have an acid in them, not good for coatings. Joe
ps> when you put the vacuum probes in the surgical tubing make sure they make a tight seal. If they don't, wrap electrical tape around them, no not on the needle too, so they make a tight seal.
Oh yeah, a duster can. Do not blow down into an ep with loose lenses. THE LENSES CAN TIP OVER.
Posted 07/01/2007 09:23PM | Edited 07/01/2007 09:30PM #4
A few have PM'd me about the needles and suction cups I suggested.
One, you don't really need the metal needles. The suction cups will fit in the surgical tubing, but it's up to you to make sure they fit tight and don't fall out.
Two, I also use syringe caps to do fine point suction. Just drill a hole through them. You can ask a hospital to give those to you for free since they just throw them out. The bigger ones fit pretty tight in the surgical tubing and are already nice and pointed, but not hollow at the very tip. Not hard to drill out or stick a finishing nail through to open.
Sports ball needles are cheap. Just file off the end until it's nice, remove the burrs.
http://www.swastikenterprise.com/inflating-needles/sportsballs.html (shown for the picture)
As you see, lots of stuff work. You can also buy needles at the pet store.
Folks, you can be creative. Just make sure it's plastic touching the lens when fine point suction is used. Never use the metal needle only.
I'll post some pictures tomorrow.
Posted 07/04/2007 01:51AM #5
Some have asked about the needles. I use hypodermic needles and grind the ends flat. To give you a picture here's a site with a picture.
http://www.stanleysupplyservices.com/product-group.aspx?id=12359
Now mind you, I can't remember which gauge is the bigger diameter but assume the smaller the number the bigger the needle, put please correct me on this. You want a pretty big diameter needle for good suction.
So if you buy the suction cups from the one site I gave you, you still have to buy the needles separate. I use glue dispensing needles from Techcon that are made out of polypropylene and won't scratch the lens when doing fine point suction around the lip of the ep. Look at the red colored needle in the picture and you'll see the needle portion is made out of polypropylene. This is what you want for simple fine point suction cleaning.
Also, in the picture you'll see to the far right the needle looking cover or syringe cover that's pointed and not a needle. This is what I'm talking about if you want to go to a hospital and ask them for a syringe cover. These all fit into the I.D. of the surgical tubing I told you about. Joe
