Jay Messeroff
Lunar & Solar Transits
Wide Scan 20, 30 mm From APM
Started by Anders Asp, 10/15/2003 12:00PM
Posted 10/15/2003 12:00PM Opening Post
Hi! has anyone tested this eyepeices (wide scan series) from Marcus Ludes APM. The Wide scan series seemes ok to me.?
Posted 10/16/2003 03:59AM #1
I just received a BW-Optik 30mm 80 degree eyepiece from Anacortes. Is this from the same family as you are asking about? Maybe it is a cousin to the widescans. I think I have seen Markus Ludes mentioned with this eyepiece. Anyway, I have an f9.6 scope, so I think it works great. I can see a slight bit of fall-off as you get near the edge, but I have to look for it. As a test, I tried the double double and could easily make out the correct orientation with this eyepiece, (although I would normally want to do something like that with a bit higher power). It is also much more comfortable to use than I had expected. This one definitely goes in my best buy category. I hope this helps.
Charlie
Darkness - typically 6.5+
Focus - JMI Smart focus
