Zhummell 3mm EP
Started by BABOafrica, 07/04/2012 03:24PM
Posted 07/04/2012 03:24PM Opening Post
I got a 3mm EP (basically a Xmas gift). It's a Zhummell. Seems to be pretty good quality from the look of the EP externally.
I've tried it a few times mostly on planets, with no success.
I guess it's just too much power for my 10" Dob, with a FL = 1118mm (making the mag close to 400X).
I read somewhere that you could go up to 50 times the diameter of the mirror.
Last night I tried it on the full moon. All I could see was a very fuzzy view (e.g., a crater) and then the edge of the moon quickly floating out of the FOV. I tried getting the focus as perfect as possible, but nothing seemed to improve the view.
Any comments?
Clears,
Joe
In lumine tuo videbimus lumen.
8O Home-made 10” Dob / Home-made 4” refractor
EPs: Konig 32mm (1.25") / Zhumell WF 30mm (2") / Nagler 13mm T1 / Orion Sirius Plossls 25 & 10mm / Zhumell Plossl 9 mm / Meade MA 9mm
Posted 07/04/2012 05:16PM #1
HI Joe,
Actually, the the idea is 50x per inch, so 10" = 500x. This is not a perfect statement, but if the conditions allow, the 50x rule is fairly accurate. But if the seeing is not that good, then you will not get to this magnification without loss of details, call it empty magnification.
Posted 07/04/2012 06:08PM | Edited 07/04/2012 06:08PM #2
Joe,
For this magnification, lots of things need to be well controlled...such as your scope collimated well, the mirror thermally acclimated well, the target high in the sky, and most important the seeing stable and transparency good. These tend not to all come together easily.
I've had 400x and 500x and more perform very successfully with a 10" Dob. I would say that for now you use the 3mm for more forgiving targets (i.e., Glob Cores) and enjoy what it can do, then when all other conditions seem in place let it strut its stuff on lunar/planetary.
-Bill
Posted 07/04/2012 06:45PM | Edited 07/04/2012 06:46PM #3
At those powers you need perfect seeing and a highly corrected mirror. Are you sure you have a parabola on that mirror, and not just an approximation of one? Do the stars shimmer, dance and bloat inside and outside of focus, or do they sit still, presenting a concentric Fresnel pattern on either side of focus? With perfect stable seeing and a really good paraboloid, you can reach 800x with a 10" Newt and have a sharp view.
Rolando
