Jay Messeroff
Lunar & Solar Transits
9 foot paper mache dome
Started by Phil Barker, 06/05/2005 11:17PM
Posted 06/05/2005 11:17PM Opening Post
Will be posting photos later but I'm building a 9 foot dome out of a ply frame with building paper chicken wire and paper mache.
the frame was cut with a hand zig after marking her out. All made from 1 sheet of ply screwed and wired together.
The mache is made with watered down pva glue. 6 layers are applied then 4 coats of paint.
The dome is finished except for the shutter which will be stainless steel sliding through plastic runners.
The dome structure is a 4 piece ring ring and 2 arches which are one piece. 18 ribs are screwed and wired into the shape along with cross braces between the arches. It is very strong.
Will sit atop a 1.8 metres building also 9 foot square.
PVA glue is amazing stuff when dried it is very strong. The chicken wire means hail just bounces off.
I got the recipe from a friend that build a dome that lasted over 20 years, The 17mm ply used is treated exterior ply. Should last decades.
Stray posted for the pickies.
Scope will be a 20cm lx200 and I will be doing imaging and photometery in the dome.
Posted 06/06/2005 07:22AM #1
here's a pickie of the dome as it is now.
I'll reply and post an earlier image showing the construction
Phil B
Phil Barker's attachment for post 92751
