I would welcome any comments from those of you who have personal experience with this company and their products
?comments re: Observa-Dome
Started by Rich Michal, 02/12/2003 02:46AM
Posted 02/12/2003 02:46AM
Opening Post
Posted 02/12/2003 04:29AM
#1
Rich,
I have a 10 ft. ProDome that I purchased used. I personally have not dealt with Technical Inovations personally but the person I bought my dome from had and was quite pleased with how the original owners of TII handled some minor problems,(short on some screws). I have the construction manual and all of the correspondence that took place between the my dome's original owner and TII. The manual, by my standards is quite adequate, but I have several other owners feel that it wasn't through enough, it's just a matter of how well you are at putting things together. The original owners have sold the business and I have not heard any actual reports about the new owner. There was a ProDome on AstroMart last fall by a very disgruntled owner. i dont' know what he could have done wrong during assembly to cause the problems he claimed to have. It should be remembered that the dome is a do it yourself project, the end result will be no better than your skill and expertise during construction. The dome itself is quite strong and weather tight. I have not had any snow or rain blow in yet. The only weak points are the dome shutter and actuator which works quite well but really the design could be improved, it's basically a cable windlas that pulls the shutter open and shut. The windlas motor is noisy and occasionally the cable tension might need to be adjusted. The other point that could be improved is the dome rotation system. The original owner of my dome did not install the dome rotation system, he just rotated it by hand. I have designed my own which is almost done and uses stepper motors and a gear reduction units. The problem is that Technical Inovations design use a rigid mounted drive motor which drives the dome rim by a friction wheel. If you excessive variation in rim to base distance, the factory drive system can lose traction. Their drive unit is also powered by the same 12v d.c. motor that the shutter actuator uses (noisy). Technical Inovations sold over 120 domes in 2001 and 2002 was projected at about 200 so there must be a lot of happy owners. Sirius also makes an excellent dome. If you bought either one you would be happy. I don't know how much a comparable Sirius Dome is compared with the Pro Dome. The Sirius uses a drive ring instead of the friction drive. I don't know how much that is worth but the ProDome ,IMHO, has a better shutter design. Take your pick, you'll enjoy your scope magnitudes more. It's always setup, always at temperature, all of your acc. are right where you need them, and your scope isn't being banged around trying to always set it up for those quick looks.
Funding Member
