RICHARD COFER
Re: TEC 6"?
Started by [email protected], 08/25/2002 06:28PM
Posted 08/25/2002 06:28PM Opening Post
You might want to look close at the Intes MK66 which is very close to the spec's of the TEC6. The scope in the standard format sells for around $1150 US dollars and comes with a zero image shift focuser, will accept most SCT accesories, very nice 10X50 finder, dew shield included plus the bottom plate will adapt to most dovetail mounts and its about 13lbs. I purchased mine for ITE aproximate order time is 3 months but they may have some in stock plus it came with an optical certification fro an optical designer in jupiter Fla
with 1/6th wave or better PTV wavefront, 94% strehl ratio and image spot size of 17 microns. What I like about this scope is that ITE optically and mechaniclly test each of the russain scopes they sell threw this optical shop, backs it up with excellent service plus are the only USA dealer with parts and are autherized Intes Intes/micro repair, nobody else does the repair on these scopes, they would have to go back to russia or germany for repair. I mostly like panetary work and find this scope does very well plus you can place it on a Vixen GP or clone with very good results but a GM8 would be very nice as well. There's also a deluxe one that has slighly better specs for a few dollars more. One thing that I will tell you that even with excellent optics I find the built quality of this Intes scope and fit and finish is really very good, very close to TV,AP and Tak.
