I just got a Losmandy G 9 [made for Celestron by Losmandy], and the bottom plate, which is supposed to attach the mount head to the tripod is different from those on the GM-8 and G 11 which I used to have; those mounts had base plates which were edge drilled and tapped for socket-head machine screws 120* apart which fit into L-shaped slots in the top of the tripod.
This one has no edge holes but six evenly spaced, countersunk holes for flat-head machine screws [#10 or #12, I presume]
Does anyone know if this was for a different type of tripod? The mount I just got came without a tripod. Oh, and the bottom plate has a 2" diameter hole in the center.
Any info?
Thanks
Any info?
Thanks
