Horsehead Nebula
Pier construction, materials: Alum vs Steel, etc.
Started by gweston, 09/01/2005 10:02PM
Posted 09/01/2005 10:02PM Opening Post
This may be a stupid question.. I don't know but..
If I wanted to have a pier made that will support a 10" LX200 and associated gear for observing as well as CCD imaging.. what are the plusses/minuses of the following metals? Aluminum, Steel, Iron. Steel seems the most common for piers, however others have suggested just going with Aluminum as it is apparently much cheaper and easier to work with. On top of that. It doesn't rust like steel.
Now.. if I tossed together a 6" or 8" diameter aluminum pier, how thick should the metal be?
Thicker than a steel pier? Does it matter?
I'm open for all sorts of suggestions. Cost is a factor for me smile Gotta keep the wife happy, and the baby fed!
Posted 09/02/2005 02:18PM | Edited 09/02/2005 04:02PM #1
Gary
The following website has a listing of sites under the topic "piers" which may be helpful, as well as a link to "the basics of pier design".
I'm sending you a private message.
Marc-Andre
