Gerald Elkin
House Finch
PIERS V. TRIPODS
Started by mogan, 09/12/2011 05:54AM
Posted 09/12/2011 05:54AM Opening Post
I'm a newbee and don't really understand which is better. help!
Canon 600mm L/4.0
Canon 1dMk4
Canon 1dsMk2
Canon 1v (35mm film)
AND A TON OF OTHER PHOTOGRAPHIC EQUIPMENT
AP Mach1 (on order)
MV AGUSTA f4
'00 Lafite Rothschild
Posted 09/12/2011 07:07AM #1
Hi David,
Well there are tripods that are very solid and stable and then some that are not. The same holds true for portable piers. Usually a pier is a good design and can be the better of the two. But some makers of tripods have excellent designs.
So, no clear cut answer to this question. smile
Posted 09/12/2011 12:37PM #2
I assume you are talking about portable piers, not permanent installations. Right?
Posted 09/12/2011 01:02PM #3
It depends on the type of telescope and mount. If you have a Newtonian on a German equatorial mount, a tripod sometimes creates problems because the lower part of the tube tends to bump into the tripod legs. Otherwise, a good sturdy tripod with wide legs is a good choice and probably somewhat easier to transport than a pier.
