Gerald Elkin
House Finch
Re: Orion AZ-3 mount
Started by davidcolton, 01/14/2007 07:45PM
Posted 01/14/2007 07:45PM Opening Post
Larry,
The AZ3 is the inexpensive alternative. Short of a photo tripod, I don't think they come any cheaper than this mount. I've had a PST mounted to mine and at 3 pounds the AZ3 is very stable without significant vibration. I had an Orion 80mm short tube that it would have probably handled without a problem, but I can't speak to its stability with a larger (100mm or 120mm) refractor, as the legs are a very light weight aluminum.
If you decide to get one, I suggest you clean the thick grease on the gears and inspect them for burrs. Replace the grease and it should move more fluidly.
Best of luck during your deployment.
