Jay Messeroff
Lunar & Solar Transits
C8 vs. Orion 8" F4 Newt...
Started by Wolfstar, 05/13/2010 06:45PM
Posted 05/13/2010 06:45PM Opening Post
Hello all, looking for some input.
For astrophotography with a DSLR, could I expect better results with this?
http://www.telescope.com/control/telescopes/reflector-telescopes/orion-8-inch-f-ratio-4*0-newtonian-astrograph-reflector-telescope
I currently use a C8, but I but after using a newt it seems like it would be easier since the camera attachement point is easier to see. Can I expect better image quality as well?
Thanks and clear skies.
It is what it is...
Posted 05/15/2010 07:25PM #1
Tony.
I am no pro at this and I am a fan of newtonians....
With a big chip camera like a dslr you will definitely want a coma corrector. What are you imaging? The focal length and ratio are important in determining which will best for a given object.
The sct is lighter and shorter and better corrected across the field, the are lots of accessories like focal reducers you can buy...
Posted 05/16/2010 10:00AM #2
Yes, for DSLR work I would recommend the F/4 Newt over the F/10 SCT.
Advantages are brighter images, shorter exposures (hence less dark
noise / hot pixels, also less impact from tracking errors), and wider field.
You would need a coma corrector, but these are easy enough to find and use.
The Newt might need some initial work to collimate the optics to your
satisfaction, but SCTs also can have collimation issues.
